Hi everyone,
I hope that all are well.
I wonder if anyone can offer some advice regarding the ZF4HP22 conversion that I am currently doing.
I would have loved to engaged Clive Tate to do it as his reviews are really good, however the financial effect of the pandemic and the fact that the Stag is a driver not a show piece have led me to take on the conversion myself as I don't think I would ever get the money back.
I have started with a ZF4HP22 gearbox & torque converter from a 3.6 Jaguar XJS, I purchased an adaptor plate and have successfully fitted that. I have successfully fabricated a new gearbox mount, gear linkage etc and have found solutions for the inhibitor & speedo.
The car now starts and runs, selects forward and reverse gears however I am having a problem with the converter hitting the bell housing at the pump end? When I set it up I left a clearance of 2mm between the flex plate and the converter mounting plates. I have 2mm spacers welded on the converter to facilitate the converter clearance and when the box is bolted up without the converter to flex plate bolts fitted the converter spins freely. I am afraid that if I remove the welded 2mm spacers the pump to converter lugs will not engage properly?
I have even gone to the lengths of removing the sump and renewing the crank thrust washers and now have a clearance of 0.004", so I'm right at the low end of the tolerance of 0.003 to 0.011"
I am starting to wonder if the converter for the 3.6 Jag is the wrong converter to use? I understand that there are three versions of the 4HP22 converter available, can anyone offer any advice on the correct converter.
Any help or advice would be much appreciated
Best regards
Best regards
