Expansion hose
    Expansion hose
    Just helping a friend today with a problem getting the expansion hose to fit and seal properly.
    He bought a replacement hose from Rimmers, that would not fit onto the bottle.
    I had always thought that the correct size was 8mm, but when I measured the expansion bottle is was 9mm!
    So the puzzle is why is the radiator pipe 8mm and the expansion bottle 9mm? Does this require a special tapered hose or what?
    Chris
    Perhaps the bottle is a replacement with the "Wrong" hose fitting? I would some a 9 mm hose if it is available, and a jubilee clip will easily make it a tight fit at the radiator end.
      I think the bottle is original, it has been there about 30 years or so. I dont think 9mm hose is a standard size. The Rimmers 8mm hose was massively thick so it wouldn't expand enough.
      Chris
        Would the size originally have been in Imperial dimensions? Say 3/8 inch. Regards, John.
          Have you tried softening the end of the hose with boiling water?
            I thought it was 3/8”
              So 5/16 is 7.93 (8mm) and 3/8 is 9.5mm. But hoses these days are made in metric so they will be 8mm or 10mm.
              So using a 10mm hose should more or less fit the bottle, but would be a real sloppy fit on the rad tube. But anyway why didnt they make them both the same size?
              Chris
                Though you Claimed to be a stag expert Chris quote from your previous company (Background:
                The idea for Stagweber International started in 2010 with the Weber twin-choke carburettor conversion. The originator, Chris Spain, a retired Professional Electrical Engineer (MIEE), wanted to continue to apply his mind as an engineering designer, and having worked on a Weber 38DGAS on a 3.0 litre Ford V6 engine based project, he decided to design and manufacture a kit to fit the Stag V8 engine. Following success of this project, and others like the header tank, fuse box and fan cowl he has coninued working to develop other enhancements, most of which are featured on this website.).
                just asking did you sell off your memory with your company ??.
                Just asking g for a friend .
                Glenn
                  I believe that an o ring was fitted to opening in cap to take up any slack around pipe. If not try fitting one
                  I am talking about the mk1 type of expansion bottle.
                    I have just been and checked the expansion outlet pipe on my Stag radiator and it is 8.3mm OD. The OD of the bottom stub on the expansion bottle I removed from the car in 2008 when I fitted a Volvo header tank is 8.3mm. The rubber hose still attached is marked Gates 8mm. Fits perfectly.
                      Thanks Dave, that's interesting. We have a rogue oversize bottle bottle that appears to be original but hopefully the BL ones are of the correct size.
                      Chris
                        Glenn
                        Although you may admire me and my achievements so much Glenn, I can assure you that I am not an expert in anything, more like Jack of all trades lol! You and your friend, have a nice day
                        Chris
                          There is always the K-Y Jelly option
                          (Other lubricants are available!)
                            Has Glenn been at my Gin?
                            My rule #1 "steer well clear of ebay and this forum when I am on the Gin"
                            half decent 8mm id hose should fit both ends, suggest that your friend gets in touch with RB to advise them of the issue with the part.
                              Glenn
                              Can we please refrain from personal attacks on other members, however tempted we may be. It can easily escalate.
