Hi all,
I am hoping to pick the hive knowledge bank on which types of glues you would recommend for various bit I am working on.
1- Hard top lining to the metal hardtop - something that wouldn't get brittle when dry.
2- Lining to lining (I have a tear which I am planning on glueing to a piece of lining behind to pull them together - photo attached) - probably something that can flex a little with the lining movement.
3- Hard top vertical rubber seals that press onto the B-post, this is glued to lining (photo also attached of the original seal which I'm replacing) - something waterproof, probably with a little flex/mastic like?
4- Hood stowage cover seal to body - again seems like something mastic like and waterproof for here.
As always, many thanks in advance for anyone who is able to offer their experience with these.
Tariq
Tariq
