To be honest, I looked at a previous thread (I think started by Sujitroy) on this and am not sure whether I have the same problem.
Briefly, a few years back the car started to suddenly and intermittently lose power dramatically - usually when starting to overtake!
After checking all components optically and doing wiggle checks on wiring etc., I took a look at the electronic ignition. I bought this from LD Parts several years back as the "best you can get". (red box sits inside dizzy and black ring underneath the rotor arm - Powerspark) I noticed a lot of black dust and could see that said red and black bits had been rubbing. Bought a new set up (same type) and found I couldn't get the clearance required. Had to elongate the locaton holes on the mounting plate and foumd that the Internet had discovered that problem too.
So, with elongated holes and coorrect gap I was zooming all over the place - did about 1000 miles and all was hunky dory tickety boo ...... until yesterday. Short trip to the local village and a short A Road blast and the power suddenly dropped off. Engne bay was surprisingly hot and the coil (Bosch Red) so hot you couldn't touch it. Jiggled wires, moved coil to a temporary new position on the bulkhead, ran it yesterday evening - all sweet and smooth. This morning, taking wifey to the rail station, the whole loss of power thing started again.
Limped back home, popped an old Lucas coil in and started the engine and all ran smooth - but I'm reluctant to put it to the test in real road conditions now.
Any ideas? Is my coil shot? Can it be that the electronic ignition is junk? (I notice that LD don't sell them anymore - so perhaps they weren't te best available?). Are my symptoms those of a duff coil oor duff electronic ignition? Sometimes the engine just stutters, the rev counter bounces up and down and the power is on-off-on-off; sometimes it's just like running on 4 cylinders. Only plus, is that it starts and idles always like a champ!
Drew
Drew
