I replaced the inner choke cables with bicycle gear cables, and cut off the glued-on choke knob to be replaced by one with a grub screw. When others have done this, can you advise how to best join the new cables to the metal plunger (cables at one end, knob at the other) please? Do you splice them into a short tail of the previous cable - I think I might end up with a too large diameter to work afterwards? Or do you fix some other way? Or is a different plunger available that I can insert the new cables into?
Changing the Choke cables
Babord. If you drill the cable out of the metal holder you can then use silver solder to re-attach the stainless cable into the metal holder through the holes you just drilled out.
solver solder isn’t the cheapest thing but it does work.Paul - 3 projects, 1 breaker - garage built and housing 2 white Stags. One runs, one doesn't
- Likes 1
D5154480-9F7A-47BA-96FD-4AF9F15CAB97.jpeg Have pmd you.
this tungsten carbide tool can help release the old inner cables.Last edited by jbuckl; 4 May 2022, 22:30.There are 2 secrets to staying on top :- 1. Don't give everything away.
2.
My son took it into school and had a play in the workshop. Drilling out the cable turned out to be easy. He put small welds into the two holes he drilled and then hammered in. Apparently you can't weld directly as the gear cables are treated. Will be harder to get out next time, but will hopefully last a while. Now installed and working nice and smoothly.
