Hi, Has anyone done a tutorial on fittng a new/old door handle?
I am finding it difficult to get the rod connected to the hole inside the door and also dont understand how the other rod already inside the door connect to the handle.
Your help will be invalulable. I have already scratched and broken the paintwork around the handle area, which I have repaired and sprayed and dont want a repeat of it again, fumbling about fitting it.
Edit. In the picture, does number 2 need to be adjusted to fit number 1 in the hole inside the car which is a small metal plate cconnected to the door lock mechanism,which way round shout it hook in? From the left side or right side of the metal plate with the hole?
Also number 3, where does it fit? Does the rod inside the car on the right side just goes in through its middle?
Hope all this makes sense?
