Original choke cable ..... But is this the correct one please??
    Hi all,
    There seems to be a fair bit of discussion with regard to choke cables and the repair of original ones on the forum. So could anyone tell me please - if i've struck lucky .....or not!!
    Recently bought this choke cable believed to be a never fitted original, so from the photos could anyone either confirm or deny it's the real deal (see photos). Length of both cables matches up with my well worn and clearly after market one from the car. The first photo is the only reference on the box it was in, not sure if it has any relevance or not.
    Any thoughts either way appreciated as usual
    Cheers Gord
    It’s an aftermarket stag choke cable.
    you’ll most likely need a non original knob, that will need to be clamped on with a grub screw.
    warning some of these had a poor crimping, meaning that it let go after only a few pulls, even when the throttle is depressed to reduce the extra load imparted by the fast idle cam.
    message me if you need help…. I’ve been sucked down the triumph stag rabbit hole that is the choke cable!!!!
      BUGGER!! Fair enough tho Julian, many thanks for the confirmation
      Gord
        You might be lucky and have one that was crimped on a Monday rather than a Friday Gord and your choke pulling days will be numerous and happy.
