Any recommendations (suppliers or material specifications) regarding the shaped rubber coolant hoses that fit either end of the steel pipe between the radiator outlet and engine inlet? I replaced these not long ago and the parts I fitted are already showing signs of cracking. I would like to replace these with parts that I can be confident will last a good few years. Any comments appreciated.
Rubber Coolant Hoses
Rubber or Silicone?
I use these in both my Stags, a bit expensive but good looking , most of all they are very strong and reliable. Cherry Red in one of my Stags.
You can purchase indivdual and purpose made ones as well.
https://roosemotorsport.co.uk/triump...-hose-kit.html
20220320_163145.jpgLast edited by singapore stag; 20 May 2022, 01:10.
- Likes 1
Colin.
Wherever you get them from, try to make sure that the two hoses are not the same. The top one is a 90 degree angle, but the bottom one should be about 110. A "90" can be made to fit both ends but it would be being stretched out of shape, and putting a strain on the rad. outlet pipe.
I suspect they may be difficult to find now.
- Likes 1
