Is there any harm is using a 13 psi rad cap than a 20 psi rad cap? My Stag doesn't have an issue other than it slightly leaks water from the water pump. The temp gauge behaves itself. I periodically top up the Stagweber header tank. The problem is the current rad cap doesn't have ears to grab on to making it difficult to undo. I have many 13 psi rad caps which do have the ears. The car is a Mk1 with a Mk1 rad with a Stagweber header tank. I'm aware going from a 13 psi to 20 psi could cause hoses to leak, but I'm assuming going the other way should be OK for my Stag.
Sujit
Sujit
