I have a ride height about an inch too high, so I will be swapping out the springs. Since I have found in the past that relying on suppliers info on height is unreliable I decided to make some measurements.
I thought it would be useful to compare the spare set I have with the ones I will remove to see if they are likely to get the correct ride height (14.5") and solve the problem, and to this end I have measured the following (in mm):
Spring height 313
Width 95
Wire thickness 13.2
No of turns 10.5
When I have removed the ones on the car I will measure those for comparison and post the info.
Does anyone else have any spring dimensional info to offer that suggests what works for them and what height it gives?
Spring height 313
Width 95
Wire thickness 13.2
No of turns 10.5
