Steering wheel.
    Steering wheel.
    Hi,has any one removed the paint from the steering wheel & polished the 3 spokes. TIA
    Leslie.. I don't think they were ever painted. They should have a matt silvery finish.
      are they anodised aluminium? I have often wondered.
        Think it might well be hard anodised, yes.
          The steering wheel is stamped steel with a satin chrome finish on the spokes, originally.
            Ok guys, thanks.
              I’m going to use a magnet to check if it’s steel, although some grades of stainless are not magnetic….
                Would the Triumph bean counters have strayed into the world of stainless.....
                  Nope & no need , it’s satin chrome on steel, as mentioned #5
                    the previous owner had painted the spokes black to cover corrosion i removed the wheel and carefully emery papered the paint and corrosion away i the polished coarse then fine valve grinding paste before finishing with metal polish i then bought a new leather cover from mister steering on ebay for under £20 which fitted beautifully
                      Hi,what kind of finish did you get.Thanks.
                        hi
                        i am very pleased with the finish its slightly brighter than the original i was going to buy a second hand steering wheel but when you looked closely at the wheels on ebay most of them had corrosion so i am glad i refurbished my wheel if the corrosion is deep you could use a small orbital sander its rely down to elbow grease to get the finish if you fit a cover it also masks were the spokes meet the rim as its difficult to get the finish right up to the leather
