Basically nowhere can beat this forum for tech advice and sheer knowledge, thats a Fact, so with that in mind I have to explain my problem..
Series 1 Damiler Sovereign 4.2
I had it running yesturday fine, drove out of the garage and thought I would change the pitted dizzy cap and ht leads over to push in.
Would not start after tjhis so put it all back as it was, still nothing..
I get spark at the plug and fuel to the carbs.. I think its related to the automatic choke this spits plumes of vapour out while cranking but makes no effort to fire or run. I think its given up, it wasn't great anyway...
Also I am sure I saw some water in the oil, but I keep checking it and have found no more, could a head gasket fail cause my problems ?
Sparks plugs are dry when removed so it seems no petrolo is getting to them as I would expect them to be wet after the amount of cranking I have done..
Any advice is welcome.
I intend to get all new ht leads, coil, ballast resistor etc as its need servicing.
Stu
Stu
