For anyone that saw my recent post on propshafts and vibration I've just sent this to Peter at LD Parts:
"Hi Peter,
I’d just like to say thank you for your usual excellent service and even more importantly the fact that now fitted the solid propshaft has completely eliminated all vibration my car has been plagued with for years and years.
I’ve had several CV props to cure the problem all sent back to the various suppliers as quite simply they were even worse and not fit for the job.
2018 I had a one made new by Propshaft Services and this was no better so I started to believe there was another problem somewhere else.
Thousands later after replacing diff, driveshafts, strengthened nose and bearing the vibration was still there.
I then looked at the prop made by Propshaft Services and was staggered at the amount of weight on the diff end of the prop so tried running it back to front, this almost cured the problem so I guessed it was the prop after all.
Now fitted yours I have my lovely Stag back that cruises at 70 + without the terrible vibration
Thank you again!"
So take my advice - if anyone has any problems with their propshaft and you think a new one will cure it, go to LD and get a new solid one made - it has to be the only way to go!
Cheers!
"Hi Peter,
Thank you again!"
Cheers!
