Whilst the car was with Paul near Alton last week for the new Steering Rack, Paul commented on the lumpy idle that to be fair the car has always had. He tweaked the needle adjusters a little to richen it up and that has helped a little.
Digging further on here and elsewhere I've found information regarding the Idle Trim screw located beside the plastic cover which I understand is the temperature compensating mechanism. There seems to be conflicting information on how this screw should be set - I've found info that says this screw should be fully wound in and seated (hand tight only) to ensure maximum enrichment during idle, and other comments that it should be fully open, or backed off ~3/4 of a turn from closed.
I've found mine are pretty much fully open and so I'm wondering if that is my issue.
Has anyone any advice on the setting of this screw?
