Stag 1974, the gear selection is quite loose, especially 2nd to 3rd. It is very easy to move over towards reverse. I read in a previous post (2016) about securing and adjusting bolts and springs at the base of the gear lever. Is this accessible with the gearbox in situ? Thanks.
Really slack manual gear selector
Mine is pretty good after I removed mine and readjusted the screws and yes some thick grease will assist but still a fiddle. It stopped annoying rattle and gear more precise. Remove that small front panel first and you will see screws holding the large one you can take the gear knob off and disconnect all multi pin switch’s so you have full access watch out for wiring to overdrive switch which tend to be brittle. If your taking it apart I would replace that wiring with new, they are available from usual traders!
I fitted a new clutch a couple of years ago but the gearbox was sent to a specialist to have the selector rod seals replaced as I couldn't get the rods out. Since I refitted the gearbox, the gear change has been very sloppy. Especially second across to third/fourth and changing back down or even across to reverse. I tried adjusting the pins but then the gear change is either too hard and crunches or way to sloppy but not crunching. I have wondered if one (or more) of the detents weren't replaced correctly as I never feel any resistance.
i wondered maybe if your detents were stuck or missing.
Any views welcome, thanks.
