The ROM states that, when using a strobe light to set the timing, the advance at 3,400 rpm should be 16 to 20 degrees above the static figure of 14. To my simple mind this means that it should be 30 to 34 degrees BTDC at 3,400 rpm. But there are no timing marks at 30 to 34 BTDC. I am I being a bit (or even a lot) dim here?
TIA
TIA
