Now then, as you may know my distributor had snapped and the timing was not...should we say accurate..ahem..I have set Number 2 to TDC having removed all the plugs, I am awaiting a distributor but would appreciate a set of instructions as to the fitting and timing of same all help much appreciated
Distributor fitting instructions?
This is how I do it.
Rotor arm on, put dissy into drive slot so that the rotor arm points to the fixing bolt (or the hole if you have moved the coil-still connected, for access) for the coil (this may take a few goes as the drive engages and may be a tooth out and doesn't line up-just pull it out rotate the body a bit the way you need to and re-insert. Loosely bolt the dissy into place but tight enough so it cant move on its own but you can move it.
Dissy cap on with no 2 lead nearest to the right of the rotor arm and make sure leads are connected in firing order sequence. Make sure you have battery connected and try to fire her up. Every time I have done it this way, it has been close enough to fire up.
Use timing light (i have one with a dial so I can set 13 to read zero on the marks on the pulley) to get timing to best running mark (usually somewhere around 13/14 deg btdc) by moving dissy - you will quickly work out the right direction (move it by the advance module to avoid any rogue electrics).
If you run out of adjustment before you get it to your best running setting (say it stops at 9 degrees) stop engine take dissy out and move it round a tooth. Tighten dissy bolts and replace coil if moved.
It's not a difficult job but people often have the leads the wrong way round or in the wrong order which scuppers the whole thing. I've also seen people trying to time the engine when no2 wasn't actually at TDC, but they thought it was because the piston was at the top, I put my finger over the plug hole to make sure it's on the compression stroke - you will feel the pressure build up.
Good luckPaul - 3 projects, 1 breaker - garage built and housing 2 white Stags. One runs, one doesn't
Originally posted by sujitroy View PostI can't recall but isn't there a situation where no. 2 piston is at TDC, but the rotor will be off by 180 degrees, or something like that? I think I looked at the mark on the cam to make sure.
SujitPaul - 3 projects, 1 breaker - garage built and housing 2 white Stags. One runs, one doesn't
+1 for Pauls method, but another way ensure no.2 is on compression is as follows:-
To ensure no.2 is on TDC COMPRESSION not exhaust, its possible to see the R.H. cam alignment mark via the oil filler cap... may need to use a torch.
Its best to turn the engine back say 20 degrees, then forwards to 12 degrees to have a statically timed ignition.
Originally posted by trunt View PostBut keep in mind that it seems common that the jack shaft was installed slightly out so sometimes you will find #2 shifted in the dizzy cap by one way or the other.. A whole other can of worms..Paul - 3 projects, 1 breaker - garage built and housing 2 white Stags. One runs, one doesn't
We probably need more info..
Did you take the leads off the cap? Check that they are correct and recheck your leads are correct to the plugs. Did you get the timing light on it yet? If so do you have full adjustment or is it at one end or the other of the adjustment..Terry Hunt, Wilmington Delaware
- Likes 1
If it runs but doesn't start easily I am going to take a complete guess that the ignition timing is out.
I ignore the ROM - install distributor when #2 is at TDC and the crank pulley marker is TDC
Drop the distributor in so that when fully home the rotor points towards the nearest coil mount bolt and not the furthest!!! This is the bit that I recall being wrong in the ROM.
When the distributor is in the rotor will be pointing to the #2 plug lead position on the cap, and more importantly the distributor mount to the engine block bolt will be mid way between the two ends of the mounting slot
This way you stand a half decent chance of getting the ignition timing rightStags and Range Rover Classics - I must be a loony
OK, I did do it to point the rotor at the furthest as previously advised and although it started, it became a most reluctant starter, with indifferent tickover so I will replace the distributor as you suggest, having done so, I am assuming that I set my adjustable strobe light to 12 degrees...(is 14 better?) and fire the car up...(tickover or higher revs?) to do a final adjustment?
