The car does run now many thanks to all for your help in this, I have not completed final timing though, do I complete this with the Vacuum advance connected or disconnected?
Question about final timing
Originally posted by sujitroy View Post
I got it wrong then
TerryTerry Hunt, Wilmington Delaware
Originally posted by mallardstag View PostWhen disconnected block off the vacuum port to the carb for smooth running whilst setting the timing.Paul - 3 projects, 1 breaker - garage built and housing 2 white Stags. One runs, one doesn't
Originally posted by Lingen View PostAn open vacuum pipe would make the fuel mixture leaner, but as has been said, there is no point in removing the pipe as there is no vacuum in it when the engine is ticking over.
Thank you for the that. I assumed that some vacuum is required to get the mixture into the cylinder (even at idle). Is it that it's too small at idle to make any difference? Just trying to understand this.
Vacuum in the inlet manifold varies depending on engine speed and throttle position. For example at WOT (wide open throttle) the vacuum is minimal, but at high revs, with throttle closed (overrun), is maximum.Chris
Originally posted by Wheelz View Post
The vacuum supply for the distributor is 'ported' and so it's not quite the same as the vacuum in the inlet manifold. The position of the throttle determines how much vacuum is applied to the distributor, which is zero with throttle closed, and this increases to full manifold vacuum as the throttle valve opens.
P.S. bonnietiler750 apologies for hijacking your thread.Last edited by mallardstag; 25 August 2022, 14:11.
