Over the weekend I went with my son to Mojave desert. (He's big into rockets and was testing a propulsion system) We drove for hours in my V6 Honda minivan. Average temp was 90-100 degrees. . The weather was hot and I can only assume the water through the system was quite hot as well, but the temp. gauge didn't move one bit from normal.
If I had to list things to do on the Stag to get the temp. gauge to be more stable and I'd like to keep the car stock, what should look at? My auto Stag's temp gauge fluctuates, more than my manual with OD, but he engine speed is working much harder. Maybe if I drive my manual at 4k rpm constantly, I'd see the same temp. fluctuations.
My Mk1 manual is running a stock mk1 rad. pump and fan with a header tank. I have rubber strips around the rad. No bonnet pad
My Mk1 auto is running a stock fan, a Super Gill Mk2 rad. with cowl and a header tank. I have rubber strips around the rad. Bonnet pad.
I think both cars are running correctly.
Are other owners of BW35 Stag notice similar fluctuations in temp. gauge readings as you drive?
Sujit
Sujit
