Over the last few weeks my stag has developed a tappety ticking sound, something akin to an old talbot avenger, from the nearside bank that can be heard mainly on light throttle.
So far i have checked the condition of the plugs, all ok, so moved on to checking the exhaust manifold is not blowing before I then go on to check the timing chain and tappet clearances.
The exhaust was found to have two loose bolts; lower front and upper centre. The front one tightened up ok. The centre one has been helicoiled and the helicoil has failed. So my first question, how best to replace a failed helicoil and what are the chances of doing it in situ? I really dont want to take the head off if poss.
I have also had a check of the timing chains and I am minded to replace it as I dont know its age - there is a about 1cm of deflection after the chain passes the cam sprocket and back into the head on the lhs. The rhs is taut both sides of the cam sprocket. I've looked through whatever I can find in previous forum posts and tech section but still not sure if that is normal or a sign the chain is worn out?
Finally I suspect the worst case is a loose valve guide? Is there a way of diagnosing this easily without removing the valve gear? The car still pulls well and doesn't burn oil.
Thanks in advance
Kevin
Thanks in advance
Kevin
Machine shop in question is a lot wiser now. I didn't pay for that job and although the heads are within tolerance I use a thicker headgasket.
