Yellow Passive Plating kits
    Going on from the Carb rebuild thread, has anyone use these kits attached below
    Yellow Passivate Plating - Electroplating Module (5 litres) - Frost Auto Restoration Techniques
    thanks for your help
    Not so sure the yellow passivate would look great on the carbs, but that's just my opinion. Perfect for the linkage, but not the carbs.
      That's what I was thinking about it for, sorry did not explain myself properly, have you used one?
          I get all the metalwork in the engine bay (brackets, bonnet catch carb linkage etc ) cadmium plated it is not expensive and the finish is as factory will upload pictures on Monday to show you.
          Stag Owners Club Forum has registered Tonywhite as a Trader in used parts for The Triumph Stag. 13.12.2017
            Years ago , before 9/11 & all that, you could order the salts (chemicals) from a chemists. I did that.
            The parts have to be exceptionally clean & ideally burr-free.
            The solution needs to be at 40-odd degrees.
            The results were good but the effort high.
            I found a platers that could do zinc & clear passivate or zinc & yellow passivate.
            The low cost far outweighed the faff of doing it yourself.
            a complete set of ferrous parts from a carb cost £10. Two sets was £15.
              I need to have many parts done, can anyone recommend one in Hampshire
                I've used the FART kit with success, but it takes a lot of care and patience.
                  So tempted
                    So tempted
                    You should follow through
                      Pictures of what I get plated 6480ABD9-85AE-463D-B0B3-424B15CD8B70.jpg B27BF2DD-206D-41BC-9EFF-1FF89F0B016D.jpg 8BA78C2C-7D64-459F-A636-62F3BC951C4D.jpg 0A51DD68-E56E-48A1-88C4-E47E2F9F7AB3.jpg
                        Nice Tony, I assume you had to strip every piece apart or are they plated as it is taken off the car?
                          Plated as taken off the car didn’t even clean or remove old paint turn around is about 3-4 days
                            Tony,
                            Where did you take them?
                              A place in Hounslow, if you want to send me what you want done I can take it there as I have another lot to be done.
