I had this problem once or twice before. When the window is all the way down, it wont go back up. To get it to go back up, I have to remove the door panel, loosen the 4 bolts holding the mechanism to the door. Then use the switch and window operates again. I had a conversation with Terry Hunt and he has run into a similar issue. We discussed placing a deeper stop block at the bottom of the door, so the window doesn't go down as far. Has anyone run into a similar issue and resolved it? Would stripping and cleaning the motor solve this issue?
Sujit
Sujit
