Drivers Door Lock
    Drivers Door Lock
    Hi i turned the lock and my key is stuck in, think the ;ock / barrel spun, any help would be appreciated
    Moved from technical.
    first thing you’ll need to do is get the door card off Jimmy. Then you can disconnect the rods and undo two small bolts and take the handle out. The lock barrel fit into a slot in the handle from memory so not sure it can easily rotate.
    ROM is good for this disassembly procedure.
      Thanks, any reason why the barrel would spin, iys done it befire snf i turned it bsck, its not budging now and i dont want to snap key?
        I can only imagine that the lock pins have somehow stopped engaging.
          is your car a mk1 or a mk2?
          The lock and rod mechanism is different.
          Covered both in youtube vids on my channel
          Mk1 setup is here https://youtu.be/aGl3thC_x_4
          Mk2 is here https://youtu.be/xK9xZnyQ4v4
            Thanks very much, for this , ive watched a few of your videos on you tube
              Cheers jimmyo06
              Once the outer handle is off I think you will find that the clip has come off the inside end of the lock barrel, check this parts diagram on the brothers website for the order of washers and clips that hold the barrel in place
              Order your Triumph Stag Door Locks - Handles and Fittings - Mk2 (From T21834LD, T20988LE USA) ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
              edited to add, be very careful if you take the barrel assy out of the handle. Always insert the key into the lock before removing the barrel. else the levers and springs that make up the lock might fall out. The key will hold everything in place
