Anyone else had issues with the County oil pump and oil pressure being either on the high or low side? I bought it from Robsport and they state that you need to fit their adapted and lower rated prv (pessure relief valve) spring as the standard spring it is supplied with sets the pressure too high. I've tried both and the low one seems too low at 10-15 psi at idle and 30-40 cruising and accelerating, whilst the standard spring gives 20-25 idle and 50-80 cruising and accelerating. Caught between the two and wonder if anyone else has found this? Is there a 'goldilocks' version out there? If you had to choose between lower versus higher pressure, which is better? Ideas etc welcome as always.
Paul
Paul
