auto conversion
    auto conversion
    hi, does anyone have any info on changing bw35 for a 4sp auto cheers
    Loads....... this one has been covered quite a lot, although mine was BW65 to ZF4HP22.
    Do a search on the forum using the search box at the top
    Russ
      Monarch Stag, http://www.monarch-stags.co.uk/. They do the ZF 4 speed for a couple of Thousand, can have it fitted by their mech for an additional 300 qiud.I hope this is the info you are looking for?.
      Welcome to the Soc Forum
      Sukh.
        thanks for that regards George
          cheers russ
            hi Russ would you say its worth the work,was you pleased with the results
              Give Clive Tate a ring. His number is in the front cover of the magazine (treasurer). He is the main supplier of the 4sp box. D.I.Y of will fit it for you.
                thanks bob will give him a call cheers george
                  Absolutely the best thing you can do to an auto Stag. 100mph is 3900 rather than 5300, and my fully loaded, with trailer, 1200 mile run to Eire and back gave me 29mpg and much more relaxed cruising.
                  Worth every penny, George.
                    Its a worthwhile change.
                    BW spares are becoming a problem too.
                    My BW35 was rebuilt and worked fine, but the pump was noisy.
                    I couldn't find anyone offering a new pump.
                    Thats what finally made me put a zf in.
                    The change in rpm @ speedis welcome.
                      Plus you can put a natty new legend into your gear selector
                      That's the best bit
