Have just fitted a new head gasket and refitted carbs etc.. Went to start andnoticed fuel leaking from high up from the carb body. I have checked the o ring on the bottom plug and that's fine (replaced the other one just the other week!). I think it may be a sticking float - could this be the case? If it is what can be done top fix it and if not what else might it be?
I would really appreciate the guidance and wisdom of the forum members on this one.
With thanks
Mark
ps When fitting back together I noticed a brown wire loosefrom the coil. The car has an electronic ignition fitted - one terminal has two same colour wires fitted the otherterminal alreadyhas one wired fittedalready - I wondered if the wayward wire is a hang over from the old points system or if it has some relevance? There ius a spark at the plugs....
With thanks
Mark
