Battery advice
    A fully flat battery will sulphate and will struggle to ever be reliable. Buy a new one and a quick disconnect fitting to isolate the battery when in the garage. You could invest in a solar panel charging system if the garage is “safe” to leave something outside (screwed to Dacia/on the roof) and receives sunlight during the day.
      Just fitted a halfords HB 075. Fits perfect with plenty power.
        Originally posted by Dieter H. Marschall View Post
        When you buy a new battery, make sure you buy a modern, small one with the utmost power - plus take one without a rim at the bottom (e.g. Dynalite Asia 560) . The old ones a very difficult to put into the car, as they are too big (or the battery compartment is too small?).
        Godd luck, Dieter from Germany.
        Or a loop type carrying handle! which can also prevent a battery fitting into the compartment.
        The size I chose would not fit with one, I found a battery without and it just makes it. The Duracell does not fit, The Exide will... Both are Group 24 size.
          +1
            Worth a try but the battery sounds like it's dead I used to work on battery power cherry pickers sometimes you can recover a battery by equalising them. You will need a good battery and your one off the car. Connect them pos to pos and neg to neg. Leave them for 2 or 3 days check your old battery with a volt meter after disconnecting it. If it holds a voltage then try charging it on a long slow charge. A fast charge will buckle the plates. Otherwise when you fit a new one consider a solar powered charger if there is no mains power in the garage.
              Originally posted by Ukpooky View Post
              Hadn't run my Stag for a few months and I knew the battery was flat. Jump started it to get going.
              Went out for a long drive for a few hours to charge it. Filled up with petrol, and it wouldn't turn over enough for a start - had to call out the breakdown for another jump.
              She's back in the dry garage for Winter with a full tank and tyre pressures topped up.
              Guessing it needs a new battery. Scouring the forums tells me I need an 072?
              I won't be driving it anyway for a few months so thinking I just worry about this in the Spring and get a new battery then... unless any advice to contrary?
              For those of us who don't drive the car too often, the best addition I've added to my Stag is a remote disconnect. After running the car, I simply shut off the battery and it's good to go next time. Doubles as a security deterrent as well. Dead simple to install and saves your, now, new expensive battery.
              https://www.socforum.com/forum/forum...711#post840711
              As for battery, I went with a Optima Red Top. plenty of power and it's small.
                Do you know if either of these have the 'lip' that makes these difficult to fit or should they just slot in 'easily' (as if anything on a Stag is EASY) ?
                  I have the Bosch battery. It does have a lip either end, but still slots in ok.
                  Whichever battery you go for, be careful not to buy a T-top, as these can be difficult to secure with the battery strap. You need a flat-top.
                    Just realised mine has opposite +ve/-ve terminals to the two recommended so going to stick a straight swap for what was in the before, on the logic that what comes out must go back in again!
                    Looks a little less powerful than the recommendations but if it 'aint broke don't fix it?! (even though it is broke)
                    S3 004 Bosch Car S3 Battery Bosch Group are one of the leading battery manufacturer companies in the world and have been delivering quality German engineering in the automotive industry for more than 100 years! Bosch is a world renown company name that have and still are leading the way for many technological innovations. The Bosch S3 Battery is the economical solution for many older cars that provides optimum starting power and long service life. It uses full frame grid technology, highly protective pocket separators and robust connections inside to extend lifetime and maximise reliability. The S3 Bosch car battery is the perfect combination of power and performance. Backed by a 3 year car battery warranty which the make it a great choice. With the latest technology and innovative design ensure that Bosch Car Batteries will be ahead of the game, now and in the future. They are also completely maintenance free making them a very convenient option. Bosch WET Technology - Wet lead acid batteries are the ideal choice for standard non start stop vehicles with minimal electrical needs. Ensures for reliable long service life and reliable starting power. With 15% more cranking power than equivalent batteries. Maintenance Free 3 Year Warranty *Always cross reference dimensions and specifications to your existing battery or application before ordering.
                      +1
                        Personally I would go with reversed terminals... its not a good idea having the positive terminal so close to the power steering pulley. Mine has original cables and they reached just fine.
                          Originally posted by Bakdraft007 View Post
                          Personally I would go with reversed terminals... it’s not a good idea having the positive terminal so close to the power steering pulley. Mine has original cables and they reached just fine.
                          Maybe you are right, but I guess BL considered it during hundreds of thousands of miles of development, and I have seen no need to change it in the past 33 years and >110,000 miles.
                            I fitted a Yuasa HSB072 which I purchased from Halfords. It has a lip either end but fits fine also.
                              +1
                              Worked well for me. + has 5 yr warranty.
                                I don't have power in my garage so I bought a small solar panel which I fitted to my window. When I'm not going to use my car for a few weeks I attach the leads to the battery. It keeps it charged.
                                sigpic 1977 TV8, Pimento,ZF Autobox, BMW back end.
                                www.grampianstags.net, www.gvrs.net
                                gvenilir bahis siteleri
