Hard top side and rear chrome clips
    This is a side view and rear view of the hardtop which holds the chrome strip at the bottom. I removed the strips as the PO had pop riveted it on. The remnants of the clips are plastic. Are these the correct clip? As you can see from the photo on the right, the same clips were used to hold the lower chrome strip on the rear, but for the rear, Rimmers shows this: https://rimmerbros.com/Item--i-630881 which are metal.
    Can someone please confirm what clips I need for the side and rear bottom chrome strip?
    Sujit
    This gallery has 2 photos.
    I've just been suffering two days of grief and many expletives trying to get the rear lower trim fitted to my refurbished hardtop. There was simply no way that the trim was going to clip over the retaining clips. At first I thought that the lower tongue of the new clips was preventing the trim being able to slip over the clip
      Thank you. Does anyone carry the correct clip? If not, I will check with Tony White.
      Sujit
        Hi Sujit,
        I think I got the clips for my hardtop trim from Bresco
        Bresco classic car fasteners vintage car fasteners fittings for classic vintage and veteran cars Austin Morris MG Rover Triumph Jaguar Ford Lotus Vauxhall Rootes Sunbeam Rolls Royce Aston Martin Fiat Daimler Reliant Riley Talbot Bentley Hillman Singer Humber Standard Lanchester Alvis BMW Mercedes VW
        Den
          Originally posted by DZP View Post
          Hi Sujit,
          Den
          Hello Den,
          You don't by any chance have a part no. do you? I was not able to find anything under Stag.
          Regards, Sujit
            Hi Sujit,
            It was KIT38P. It is in their catalogue, but I cannot find it on their website, so probably best to call or email them.
            Some of the holes for the rivets on the side of my hardtop had worn too wide for the included pop-rivets.
            So, I purchased a variety set of pop rivets and just selected ones that were a good fit for the hole and drilled the clips to match.
            Regards,
            Den
              Hi Den,
              Thanks, I did download the catalog and do see it. It doesn't show up on their online search so I sent them an email. I hope they still carry it.
              Regards, Sujit
                Order your Hardtop Clip Kit - RS2029 ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
                is the full kit of bits needed, also shows the plastic bits, Wonder if they are the same as the sill strip clips
