Removed the two cylinder head core plugs yesterday adjacent to the spark plugs (not the one behind the exhaust manifold). The plugs were 'thick' ones and even though I tapped on one side of the inner cup they pushed through rather than pivoted. Not an issue ... just grabbed em and pulled em through with grips.
On inspection ... 1. a previous owner (PO) used silicone as sealant ... and plenty of it ... risking detritus circulating around system and 2. the holes have one or two vertical scores; I might have caused one ... the PO must have tapped the plug home with a screwdriver or something on the rim causing a high spot that scored the hole as it pushed it through.
So ... how to ensure a good seal when putting new plugs in? Forum rummaging identifies a number of robust candidates ... Hylomar, Wellseal, thread locking compound, RTV ... but what about something like Quiksteel (epoxy metal putty stuff)?
What's current 'best-thinking'?
Thank you in advance.
