Hi All, taking a look at the gearbox that came with my project. The input shaft has significant amount of side to side movement… I know that there will always be some play until the end of the shaft is fitted into the pilot bush in the flywheel but how much is acceptable…?
If the bearing is toast. Rimmers list two options for the bearing one is 58391 then they list a more expensive option 58391RHP, https://rimmerbros.com/Item--i-58391RHP which one is correct ?
