Best way to clean an engine without removing
    My engine has been put back in the chassis by the restorers but they haven’t cleaned it as well as I was hoping.
    is it too late or does anyone have a technique that works?
    Soak for 24 hours with engine cleaner e.g. gunk or jizer.
    seal orifices. Jet wash. Keep lance 12” away from delicate areas.
      I would only add:
      - A brush to agitate is useful
      - Wear goggles or face shield and a hat
      - Wear clothes that you don't care about
      - cover the seats of the tow vehicle for the drive back if applicable
      You're going to get dirty.
        There's a truck workshop near me, I once drove my Range Rover into the yarrd and had the engine steam cleaned there - it came out spotless and started up first go afterwards.
          Thanks guys
            I use this it is brilliant, spray it on and agitate it with a brush, leave for 10 minutes and repeat the process again leaving for a further 10 minutes.
            using a garden pump spray, fill up with water, pump up to pressurise it and spray the crap off. It is low pressure which is ideal but works as it gets into all the nooks and crannies
              I would caution against pressure/jet washing unless the car can be driven after to thoroughly warm up and more importantly, dry out. If pressure washed and left there is a high probability of the water that has ingressed due to the high pressure lance causing corrosion and leading to things like a stuck clutch. This is especially true as degreasers would have been used leaving a clean, exposed, oil free metal surface, which will oxidise in literally minutes under the right conditions.
                I use a product called plus10. spray on and wipe off. needs little agitation and a water spray bottle should see the lion share gone. no need for steam or pressure washers unless you want to
                https://autosmart.co.uk/products/cp10114d-plus-10
                  Excellent idea, thank you.
                  By the way, your rebuild looks lovely. I’d love to have your skills and time!
                  Mine looks lovely but what a cost! Plus, no one ever does as good a job as one would like. Oh don’t you just love OCD!
                    I also use Autoglym, not just their engine cleaner but all their cleaning/polishing products - I don’t believe there’s anything better
                      Plus one for all Autoglym products! Used them for many years on several different classics. Regards, John.
                        I used to buy the Autoglm products until I was told about and used the Bowdens range of car care products, they are Australian made so I'm not sure if you can get them in the UK.
                        regards,
                        Raoul
