Pin - Regulator Pivot Roller - ZKC2761
    I need to replace the roller and pin on my window regulator. I only have a 5 ton press at home. Will I be able to secure this on the arm with my press? If not will hitting it with a club hammer work?
    Sujit
    Imho both.
    However the original had a small counter bore to make it easier I think.
    New ones don’t.
    maybe you could add one?
      Drew had a good piece on that, maybe in his Bavarian stag thread?
        Seem to recall doing that myself - drilled into the end of the rivet then pressed it in the vice, using a suitably sized object to spread it.
          Glad I wasn't daydreaming, I thought that too but bu$$er me if I could find it yesterday
            threaded screw and nyloc nut to replace the rivet?
            Cannot imagine that the rivet would need much more than a hearty good squeeze in a bench vice
              Post N° 1183 in the White/Blue Bavarian Stag thread
                Thank you very much.
                Sujit
