Wheel tyre savers cradles
    Hi,
    Are wheel tyre savers worth having if the Stag is parked up for up to 6 months over winter?
    I’ve never used them. Are they available per each tyre size? I would imagine they should be matched to the size of the car tyres.
    CW
      Just inflate to 40 psi for 6 months then reduce to 26 / 30 psi before driving. Simples! Regards, John.
        + this. It is a always a good idea the keep the pressure up when out of use. It is also a good idea to move the car a little to change the weight on the tyre but also it helps preserve wheel bearings. Parked caravans often suffer bearing failure for the same reason.
          Thanks, I'll blow the tyres up!
