I have just started my engine after a complete rebuild, runs well but oil dripping on right hand exhaust manifold. I have looked underneath but cannot find the source. The only wet bit seems to be the oil pressure switch. Would that leak oil ? Nothing appears to be coming from the oil pump or oil transfer cover. Any suggestions please.
Oil leak
Pressure switch shouldn't leak oil, if it is leaking around the thread give it another 1/4 turn. if it is leaking past the electrical connector get another one.
Oil pump and transfer housing are common leak points BUT so is the half moon seal on the back end of the RH cylinder head.
Good luck and well done getting it up and running againStags and Range Rover Classics - I must be a loony
- Likes 1
