Instrument bezels
- Likes 1
Thanks for the info. I would like to go for the original look, black with thin chrome rim. I will have the instruments out to re veneer the wood, My intention is to remove the bezels, spray them matt black, then lay them on a flat surface and using a cutting compound, gently remove the paint from the high point on the rim, revealing the chrome. Simple...or perhaps it's my OCD playing up again!
The problem I had when I tried that is that to get the satin black spray or rather it's etch primer to adhere properly or in some places, at all, despite meticulous degreasing, I had to scuff up the underlying chrome, and then the option to try to remove a thin "ring" of the paint wasn't really there any more. So I gave up and ended up with full satin black surrounds, i.e. a MK1 finish in my Mk2. Still looks miles better than the original flaky black paint. And yes, I know not all the screws are in.Originally posted by Mervyn Waugh View PostThanks for the info. I would like to go for the original look, black with thin chrome rim. I will have the instruments out to re veneer the wood, My intention is to remove the bezels, spray them matt black, then lay them on a flat surface and using a cutting compound, gently remove the paint from the high point on the rim, revealing the chrome. Simple...or perhaps it's my OCD playing up again!
IMG_4656r.jpgLast edited by wilf; 17 February 2023, 11:52.Header tanks - you can't beat a bit of bling.
- Likes 2
I have not tried this on instrument bezels but I have on other small bits of trim etc where it is difficult to mask off what you do not want to paint. This is to put a smear of silicone grease or Vaseline on your finger tip. With a steady hand wipe your finger tip over the piece you do not want to paint. Spray paint your item and let it dry. Once dry wipe your item with a clean cloth, the area where you wiped your finger will clean straight off leaving the area underneath paint free. Easy and only takes a minute to do. I once done this to a set of alloy wheels when much younger when I could not afford powder coating. A trick I have done a number of times since.
- Likes 1
Wow, think I am converted to full black, that looks very tasty, is it satin?
Sort of makes chrome look a bit, dare I say it, tacky...Last edited by Mervyn Waugh; 18 February 2023, 00:43.
Yes, satin black. I had also very carefully cleaned the instrument glasses and glasses, and used compressed air to (gently) blow out the inner workings and casings to remove "bits". New sealing rubbers, too.Last edited by wilf; 18 February 2023, 08:59.Header tanks - you can't beat a bit of bling.
- Likes 1
