Glovebox light switch
Hi Sujit,
The switch offered by E J Ward (and most retailers I believe) will serve the purpose, but (in theory) the original causes less strain on the attached wire and connection because the deflection when the switch operates is at right angles to the axis of the wire, not in line with it, and there is a button on the end of the plunger which acts as a retainer for the sponge doughnut. The doughnut is high density foam, it acts to push the glovebox lid open when the latch button is depressed.
I should imagine second-hand ones are available, postage shouldn't be too expensive !Attached Files
