Hello I am looking for a couple of bits of advice.
I'm trying to remove the differential, I have undone all the bolts I think I needed to (disconnected drive shafts, front four bolts (diff to extension), back diff mounting plate to body (nuts, washers and rubbers). The diff with some helped then dropped a bit, but at no point did it threaten to part from the extension. I can only think it is due to where I have supported the car and there is no twist available for the extension to allow the diff to slide/fall out of the extension.
Does that description sound like it is possible or have I missed something?
Related to the above, but also needed as independent advice. I should explain at this point that I don't believe I can use the jacking points on the sills - at some point my car has had new outer sills fitted and it looks like jacking points are missing.
Where should I support the car on axel stands? (I have confused myself reading through past posts on this and similar questions so I'm afraid I'm asking the question again).
Also is it possible to support the car on the body and if so where by?
Any advice or ideas would be most appreciated.
