Hi guys over the course of the winter when I had my car laid up while I refreshed the rear suspension I have lost quite a significant amount of atf from my bw65 gearbox. Thankfully I had a large 2 foot by 4 foot double folded piece of cardboard under the car and it is absolutely saturated in atf.
I cleaned up the gearbox with brake cleaner as it was not obvious where the leak was coming from. I had read on here that the selector seal is a usual suspect, but left overnight I can see that I have a significant leak from the speedo drive. The picture attached shows the leak after only a few minutes of cleaning it dry. I have not found much in my search on here for this. I am not sure if this is the only leak, but I need to stop this first before I go any further.
I see from part suppliers that there is a seal and a couple of o rings in the housing.
So question I have is are there any gotcha’s if I remove the speedo drive from the housing ?
Am I likely to have a flood of aft when I remove the seal ? Are the seal and o rings easy to remove and replace ?
I have just come to realise that the rom I got with the car does not cover the bw65.
Is it safe to start the car, not drive it just start it, if the amount of atf is very low ?
Thanks in advance for your wisdom.
