Good afternoon, can I lean on the collective’s knowledge?
My car (which I have had for 1 year now) came with a kenlow fan installed. When out in the hot period last year the fan came on and fuse 3/4 blew (fan came on because viscous coupling needs replacing). There was also evidence of heat damage to the fuse carried board. On investigation I discovered that the fan was drawing power directly from fuse 3/4 even though there was a relay present in the circuitry. Over the winter I have replaced the fuse box and rewired the kenlow as the attached kenlow wiring diagram. This takes a feed direct from the battery to a fused relay. This works fine for the override switch, however the fuse blows (in the fuse box on the low current side of the circuit) when the Kenlow thermostatic switch activates.
If I wire it so that either only the override switch or the Kenlow thermostatic switch are used to trigger the fan all is well. As a result there is not an issue with the individual components. My thought is that in providing power to both sides of the Kenlow thermostatic switch it is creating a short circuit and that the override switch present is not the 'special' KLM0570 switch noted on the kenlow wiring diagram attached.
Does anyone have any observations/thoughts/ideas in this regard?
My thoughts to resolve this is to provide two relays, one as a trigger from the Thermostatic switch and the second as a trigger from the override switch. This looks OK to me, but I am not an electrician. Does anyone see any issue with this proposal as the 2 relay wiring diagram attached 2 relay wiring.pdf ?
