Hi guys I have just replaced some seals, filter and the sump gasket on my bw65 auto gearbox after losing all of the atf during the winter. Hopefully I have now fixed the leaks.
Question, is there a process I should follow in refilling the auto box. I assumed that it was completely empty after removing the sump cover and will need the full 5.4 litres of atf to fill.
I have only managed to get 4 litres in so far and the atf is brimmed to the top of the fill / dipstick tube.
Should I be running the engine to get the right amount of atf in ?
If I do run the engine will I get a whole load of atf in the engine bay from the full tube or will it get sucked into the box ?
In case anyone asks the breather tube is clear as it has been burping at me while filling.
could there be air locks, perhaps to the oil cooler which I have also replaced.
TIA Alan
TIA Alan
