Hi All
I have made up a water pressure and leak test home made jobby which consists of a pipe from the top of teh rad to a T piece and one pipe goes to a pressure gauge and the other goes to a pipe with a tyre valve on the. Idea being I can see what pressure my system is running at when engine is running or, when engine is off and cold say, I can use the tyre pump to pressure the system to to either 13lbns which I have or 20lbs and then look for leaks.
Had engine running with temp gauge on a 1/4 as normal, pressure gauge doesn't move :0 Turn engine off and put on type pump and gauge goes up to 13lbs and then the bottle cap lifts so all working well
So, I know the gauge works so why doesn't the gauge read at all when engine is running for 10 mins at least?
Sorry if I this is a stupid question, but I have been in the sun today
Andrew
Andrew
