Hi my dashboard is a bit on the dark side not very bright , well i only had them on for over an hour and half when i bought it , they got brighter as i got home, where can i buy them please ?
dashboard bulbs for gauges speedo etc
good evening all , took cover off cr , started 1st time , happy face
cleaned rocker covers, werent that dirty but now , like newish.
let car idle for about 5 mins went for a drive gearbox changes fine , except I get tha clunk in reverseany ideas guys?
fiddled about with dash dimmer switch , the pic im going to add was the best i could get , what do you think it was not really dark outside about 9pm.Attached Files
Here is a picture of my dash with green leds from classiccarleds.
- Likes 1
I got some cheap ones off Ebay for both my Mk1's. Had them on the car for a few years now, but only drive the car now and then I'm sure if you are in UK, you can find the source as then seem to come out of Asia. . I had to remove and clean my glass as the dirt shows up more with LEDs : https://www.ebay.com/itm/154004970380
Originally posted by APS View PostHere is a picture of my dash with green leds from classiccarleds.
Jimmy you can select a kit which includes all of the bulbs you need or the bulbs individually.
on my car I have done all of the bulbs except the headlights and the warning cluster. Very pleased with the results, especially the rear brake lights which are much brighter than the originals and the dashboard lights.
Simple Plug & Play Triumph Stag Interior, Exterior and Headlight LED Bulbs upgrade Kits. Dramatically reduces load and increases visibility
