Hi Gents,
Sorry to be going over old ground again but I'm trying to fit an indicator cancelling cam and having removed the column covers I can't see any dimples in the shaft as mentioned in numerous other posts?
I have attached a few pictures so you can see what I'm faced with. It looks to me as though the brass coloured bush has moved up the shaft and has covered where the dimples should be?
If I refit the steering wheel and rock it the bush moves with the shaft which again I'm not sure is right?
Not sure if there are any differences between early and late Stags but mine is a 1977
Any thoughts or advice would be great !
Thanks, Peter.
Thanks, Peter.
