PAS Pump
    PAS Pump
    My pump appears to be leaking from somewhere (not the pipes) so am wondering if it's better to buy the seal kit or just swap it for a rebuilt one from one of the usual suppliers.
    I have seen posts about both routes, but no definitive answer.
    Any thoughts gratefully received!
    Jeff
    if u are talking about your power steering pump, your rack is most likely leaking. take the steering rack gaiters off and see if fluid is in there. I've rebuilt 2 pumps. they typically stop working or should I say stop producing pressure than leak.
    Sujit.
      Thanks Sujit - can't be the rack as it is wet under the pump itself and it would defy gravity to be there.
      As the pump seems to work perfectly and after a kind tip from Goldstar Paul, I think it may have been an overfill that leaked out. I am going to try his suggestion of talc to see if there is a leak.
      Jeff
        The reservoir to pump body has a oring seal afaiaa.
        that can be the cause of a pump leak if it’s not the pipes.
          Mine leaked when the metal split around the return connection.
            Thanks Julian, I was wondering if there was a seal there. I'll see how it is after the weekend.
            Jeff
              Thanks - I'll check that too.
              Jeff
                I have a YouTube video on one I rebuilt. search Triumph Stag - power steering pump. Sujit
                  Thanks Sujit, already watched it! Very good.
                  Jeff
