Do you have electronic ignition fitted?
If you have, then you need to get the rev counter rewired to cope properly with modern electronics. You currently have 4 wires in the back. This will be reduced to 3. Two of the wires are part of the ignition circuit (I can't remember from memory which ones, but light green rings a bell), and as you mention, when you disconnect them, the engine cuts. You can wire these together to complete the circuit and bypass the rev counter; this is basically what 'speedy cables' (see below) will tell you to do. Their remaining wires will run to + and - on the coil and to earth.
Try 'speedy cables'. They sorted mine out for about £50. It had exactly the same symptoms as yours, as did the replacement, until fixed. They also supply wiring instructions for refitting.
If you don't have electronic ignition, using a wiring diagram, you'll need to trace and check wiring connections, earths, etc.
cheers steve.
