BMW master to brake pipe
    Does anyone know what size or thread the BMW master cylinder inlet is and is there an adapter for the standard brake pipe fitting to fit the master?
    Ive got the BMW servo and brake master cylinder fitted but not plumed in yet, think it would be metric maybe 10mm or 12mm, John KOY should know he has one fitted and working
      Cheers Dave
        Andrew where did you get it from and what model does it come from, how much do you need to bend the inner wing for it to fit?
        Bug attractor 2
        Ps how much difference does it actually make?
          I got mine from a BMW E30 but E36 will also fit, Where the servo is bigger you need to reshape the inner wing where it meets the servo
            Dave but how much 10mm ,20mm ?
              I think it’s a matter of “fettling” to fit Martin. From seeing people’s cars with it fitted it isn’t much nor is it noticeable when “modified”
                ok thanks
                  Hi CT.
                  I used a piece of 4x2 with one corner radiused to match the servo, a few bonks reshaped the wing, trial and error as Goldstar says. I previously had Greenstuff with original servo. Changed to Mintex1144 pads with BMW servo. Brakes have more bite even when cold. Would never go back, much more confidence inspiring
                    Thanks john, hope you are well and enjoying the weather, but not the holiday makers I think
                      Hi All
                      This is the master cylinder which is presumed to be a BMW E30 and these are the inlets and one is larger than the other. This is not my Stag so don't know the history. One inlet is larger than the other and mot sure if there should be a reducer or adapter. Is this an E30 master or maybe and E46.?. All good fun eh?
                      Andrew
                        I would think one is 10mm and the other is 12mm thats the same as my Sprint
                          Thanks Dave
