Hi All just thought I would share this in case anyone else benefits.
I ordered some shims for the front vertical link to strut. ROM says these are used on either side of the spacer to fine tune camber on the top front lug only.
On Rimmers website they list the shims also they list the bolts used in the bottom two holes of the strut (these are 3/8" bolts) unfortunately in the info for these 2 x 3/8" bolts they quote the info in the ROM about using the shims and spacer. However this is incorrect as these are the two lower bolts and do not need the spacer or shims.
So the shims that Rimmer supply are 3/8" hole size shims so will not fit on the upper bolt as this is a 7/16" bolt.
To be fair to Rimmers the pics in the ROM are not overly clear either !
