Timing
    Timing
    Where can l find the best instructions on setting up the timing ? Has anyone done a viseo on it ?
    Ignition?
    put a strobe on no 2 spark plug.
    Slacken distributor clamp bolts.
    Turn distributor until the strobe shows 12 - 14 degrees advance at idle speed.
    Usually without vacuum connected but block the pipe.
      The hardest bit is getting at the distributor clamp bolts…
      which reminds me I need to get a long 7/16 spanner and bend it!
        remove the ignition coil first and any 7/16 AF spanner will get to the distributor clamp bolts
          I made a spanner for the job …. It was an offset ring 7/16”
          …. can never usually find it though
