Water pump cover
    Water pump cover
    How can you tell if you've got a 6 vane water pump cover, or a 12 vane ?
    ​​​​​​​P.S Im going to reb
    The 12-vane is a shallow angle - about 29 degrees. The 6-vane is a much steeper angle. Looking on Rimmers might give the part numbers marked on the casting?
    Chris
      Afaiaa you can’t tell until the cover is off.
      Be good to hear if there a way to tell beforehand though.
        Thanks ill look at the angle of the cover
          Ive got the cover off, but found there's no impeller on the pump so thats another thing ill have to find when i rebuild the pump
          ​​​​​​​Dave
            ​​​​​​​Dave
            What??? Someone nicked your impeller? How they do that?
            Chris
              Pixies, those damned pixies steal anything and everything
                I think it looks like i need a 6 vane water pump impeller, who sells them or is it only second hand one ?
                  Pmd you.
                  afaiaa only currently available used… or remanufactured as a complete pump…. But with a non original press fit impellor.
                  beware… impellors seal face often need a skim.
                  beware … seals being offered & readily available, do not give the correct torque to turn.
                    I’ve just stumbled across one in my shed Dave. I’ll text you some pics of you still need one.
                      TD Fitchett of rear diff fame have a NOS 6 vane impeller on eBay right now: https://tinyurl.com/y4uehz9h
                      Jeff
                        Dave’s old shaft & cage. Fitted with some new parts.
                        it did get the cage orings & grease added too.
                        nice low torque to turn .
                        bon voyage dave!
                        71676609124__313B3DCF-0A3F-45DF-8C54-1DC900E3A4D4.jpg 71676607723__7ED5D208-A780-49BA-852B-072C6D6CE23A.jpg
                          The shaft was good.
                          Rest was missing or mullered.
                              Nice work Julian.
