I'm making the most of my membership this weekend... :-)
I KNOW there's no logical reason to mention this, but yesterday I replaced the Brake/Rear light bulb (offside) on my car - all straightforward. But in the wild extremes that it might be relevant...
Went for a shortish drive after the bulb fitting and at some point noticed the Ignition light was staying on. No revving of the engine or speed changes made any difference. Left the car in the garage for a while and started up again - same issue. The battery terminals are clamped onto tightly, the fan belts both taut and spinning well.
Does this mean the alternator is the culprit, or is there anything else to check? Not sure how old it is or if it's been replaced by previous owners (need to go through the files) - Suggestions anyone? Cost of a replacement isn't huge (about £80.00). How much of a pain is fitting?
Thanks in anticipation....
Greg
Greg
I'd not have a clue as to the electrical processes that go on. My capability is to make a circuit and check there's + and - connections. And on a good day that there's an earth. I'm not a mechanic or electrician - at best a 'bloke who fiddles about with hope'...
I'll be having the gearbox out next... I now have the cluster on the desk beside me and have removed the ignition bulb. As you may have gathered I am not the most technically gifted, but the Ignition bulb looks to me like an incandescent bulb compared to the other LEDs. I've done the best I can to photograph the bulb under a magnifying glass. So it could be that Classic Dreamworks who fitted the LEDs for me along with the new dashboard were aware of the issue of LEDs on the IGN lamp. The Handbrake light bulb is similar. Whereas the other lamps are round bulbous style.
